Hey guys, I posted this over on a Honda board but BITOGers are famously good troubleshooters, so I thought I'd try here too:
My D15B7 (95 Civic LX) is stock and had been running well up to this point. Idle was rock solid for the 2 years I've had it but recently began to randomly go low at stop lights. I cleaned the IACV (or EACV as per FSM) and the FITV with the help of the FAQ and they both got new o-rings.
Today the idle got rough; you can feel the engine shaking at a stop light. When I push the brake pedal, the idle drops further. Turning on the blower fan drops it even more. Pulling into my driveway I stopped, mashed the brake, and it stalled. It has NEVER stalled out on me before. I'd appreciate any pointers as I start the troubleshooting game.
Investigating further it almost sounds and feels like one cylinder isn't firing, or at least not consistently. If I pull plug wire #1 while idling, it dies. If I pull #2, idle drops or sometimes doesn't seem the change. Wires 3 and 4 seem to just drop the idle.
Here are a few of the obvious things:
- Engine seems to run well once it's out of idle mode
- No obvious or audible vacuum leaks, but I'm not sure the best way to check
- Spark plugs are new NGKs and in good shape
- Wires and new NGK
- Cap, rotor are pretty new
- Timing is right at 16*
- Fuel injectors all read 12.5 Ohms
- Recent coolant exchange, bled like usual (but could be worth checking again)
- Valves adjusted maybe 10-15k ago
- Does not overheat
- Disconnected the battery for a while with no change
Thanks for the input.
- Wires and new NGK
- Does not overheat
