What oil should I use in a 1994 geo prizm (Toyota corolla) with a 1.6 liter engine (4A-FE) and a 5 speed manual transmission? The engine rarely sees more than 4000 rpm and I try to rev match when possible. I drive it to and from school mostly, so I occasionally have to drive 70 to get to class on time, but I typically drive 30% highway driving at 45 mph, 50% freeway driving at 55 mph, and 20% city driving at 40 mph with about 16 stoplights round trip to and from home. I drive the car hard somewhat when I am running late and need to time the lights, but otherwise I try to drive it easy. I live in ojai, lowest temperature I see is 20 F with the highest being 110 F, college is in Ventura with temperatures rarely going above 90F or below 40 F.
The engine is out of a 1995 model, I am burning minimal oil between changes even though the odometer is at 250k, the seller claims that the engine has less than 100k on it.
Recommended oil is API service SH SAE 10W-30 for temperatures 32 F and up, 5W-30 for temperatures 50 F and down. Recommended oil change is every 7500 miles unless severe driving conditions, than it is 3750 miles.
I'm running the walmart brand of conventional 10W-30 oil in it right now.
