Hey Guys,
I just found this when reading up on "Freindly_Jacek's" post about the Prius piston issues and Kreen/B12 on this other thread:
"Toyota Hot Piston" issue by Friendly Jacek
and I was curious about the problem you guys were having as it seems similar to other TSB's for the Caddy North Star and the GM Piston and Ring Cleaner used for some GM piston ring problems like the Saturn which are all solved by drilling holes into the piston oil ring land from what I remember reading as the solution.
Since the Toyota TSB mentions a piston skirt temp problem, has anyone thought of a way to address that heat problem?
Here's just a few ideas if it is maybe also a localized problem of overheating the oil film in that area and my thoughts would be to try to lower those temps with an oil cooler, and run Evan's Coolant which is a very different technology that has been proven to lower hot spots and focalized boiling within the water channel s in heads to prevent detonation.
Just a thought!
Maybe some gourmet or boutique $$$$$ synthetic oils that are out there to control friction and/or prevent the oil from vaporizing or whatever.
There is also a combustion improver that has been out for years and has lost its luster but apparantly, the technology is fairly credible since it is really touted for industrial uses. Remember the RXP Gas Kicker Fuel Additive? It was marketed as a way to improve combustion gases to beat smog tests, but also decarbonized combustion chambers in the process...... Their scientific paper discusses their theory of Radiant Containment. They have a few different older websites that I thought discussed the theory in more detail and how I think it lowered piston crown temps. Here it is:
RXP Scientific Explanation
There is also another industrial fuel additive that is supposed to stabilize combustion chamber temps by its affect on the physical properties of the fuel droplet size called "VISCON" where I had posted some info on the site, and there are some old post going back 6+ years that discussed it when it was available to consumers. They have only just begun to start up their consumer marketing program again, but mainly geared to quantities to treat large quantities of Big Rigs tanks and was available at a few different truck stops in California to the trucking industry.
Not sure if any of these suggestions can combat the Toyota Piston Temp problem, but maybe something could work without taking the motor apart.....
It makes me wonder why Toyota wants to have more oil in the crankcase....maybe that would drop oil temps and/or prevent dilution of the additive package if the oil was run low.
Hope this helps and maybe others can come up with other ideas to lower piston skirt temps. to see if that resolves your problems.
Regards,
Chris
