Originally Posted By: The Critic
Originally Posted By: 3311
Ok, am I the only one who doesn't see a problem here? The torque for a high grade 12.9 22mm hex/14mm bolt is 234 nm or 173 ft lbs. Critic said he was at about 250 lbs of torque an was using an impact that puts out 750 lbs. Is my math not correct? If it is, I think the socket was fine, just way over torqued. I'm thinking he was lucky he didn't break the part/bolt.
The Toyota torque spec for those bolts is 177 ft-lbs. The 250 ft-lb number was a guess, I just hammered at the bolt for a while with my impact (not sure what I was thinking, probably was being rushed), and the torque wrench just clicked. I would guestimate that the final torque was probably somewhere between 200-250 ft-lbs.
And yes, I should probably replace the bolts at the next strut replacement....they are suppose to be replaced each time, I believe.
Yeah, probably a good idea to replace them when you can.
