Half Price GTX 15W-40 @ REPCO in Oz
by SR5
05/27/16 03:27 AM
1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
05/26/16 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
05/26/16 10:07 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
22 registered (cobra7279, bbhero, chrisri, Bandito440, 3 invisible), 474 Guests and 331 Spiders online.
57996 Members
66 Forums
249469 Topics
#288023 - 05/24/05 07:45 AM What does gas line anti freeze do??
frankiee Offline
Loc: Canada
What does methal hydrate do??
My fathers vehicle was acting up so we tried a fuel filter and it randomly did it after so I told him to put in some gas line anti freeze.
Does it emulsify the water and gas so it is a solution? Does it nothing more then lower the freezing point. Or does it simply displace the water some where else
Thank you
#288024 - 05/24/05 08:45 AM Re: What does gas line anti freeze do??
GROUCHO MARX Offline
Loc: The Sandhills of NewYorkistan
Unless I'm mistaken, it's alcohol.
I would try some Chevron Techron. It's the only OTC additive for gas that I've noticed a difference with.
#288025 - 05/24/05 09:02 AM Re: What does gas line anti freeze do??
labman Offline
Loc: Nothern USA
Methyl hydrate is a stupid term meant to make the use of methyl alcohol or methanol sound exotic. I would never buy anything from any company that are such jerks as to use such a term. It is like ''synthetic brake fluid''.
Water and gasoline form two separate phases or layers. Add what ever you want to call CH2OH, and it will divide itself between the 2 phases. The more you get into the water phase, the lower its freezing point. As long as it is still frozen, a very small amount can block a fuel line. If it is a liquid, it will be pumped through the fuel line, possibly stalling the engine when a slug of water hits the combustion chambers. You can still restart the engine when some gasoline comes through. Add enough, and you will have one phase, which the engine will run on fairly well. Once you get water in a gas tank, it seems to take forever to get it all out.
#288026 - 05/25/05 10:09 AM Re: What does gas line anti freeze do??
1maniac Offline
Loc: Pittsburgh PA
Beware using the cheaper gas line anti-freeze. It can plug your fuel filter. The isopropol stuff is a little more expensive but works a little better IMO.
#288027 - 05/25/05 11:42 AM Re: What does gas line anti freeze do??
mechtech Offline
Loc: Chicago area
All gas around here has alcohol in it, and additional tiny amounts are a total waste.
#288028 - 05/25/05 07:34 PM Re: What does gas line anti freeze do??
labman Offline
Loc: Nothern USA
quote:
Good point. With 10% ethanol, you should never need to add any more. On the other hand, how much more water can the gas stations get away with pumping along with the gas?
#288029 - 05/27/05 06:17 AM Re: What does gas line anti freeze do??
c502cid Offline
Loc: Elizabeth. Colorado
When gasoline has alcohol in it from the refinery, wouldn't it stand to reason that it is absorbing even more water from the moment it is made, transported, and ending up in your tank, therefore you still need to add isopropyl alcohol to it anyways?
#288030 - 05/27/05 06:56 AM Re: What does gas line anti freeze do??
labman Offline
Loc: Nothern USA
quote:
At every step from the time the gasoline base is produced at the refinery, I am sure it has a smaller surface to mass ratio and a more sophisticated system to separate the gasoline and the atmosphere than in your gass tank. I see no reason to add more alcohol yet once it reaches its most vulnerable point. If there is a problem, I would choose methyl alcohol with about half the molecular weight and a vaporization rate closer to gasoline than isopropyl alcohol.
#288031 - 05/30/05 06:59 AM Re: What does gas line anti freeze do??
steveh Offline
Loc: wisconsin
I heard that the isopropyl is the only type that will get rid of the water and that the cheaper methyl alcohol will only prevent freezing.
#288032 - 05/30/05 08:17 AM Re: What does gas line anti freeze do??
mechtech Offline
Loc: Chicago area
Most over the counter additives are methyl, not isopropyl alcohol. The iso is the expensive stuff.
