JHZR2
Staff member
Hi,
Im looking for a bit of education on pressure pots and spray guns.
I had asked for leads on pneumatic sprayers here:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2874738#Post2874738
But really think Im asking for the wrong thing.
I think what Im looking for is a paint pressure pot, but one that feeds via one line the air and material.
On the system I was looking for, the item really looks more or less like this:
Which is from Lemmer.
However, it appears that HVLP guns for airless spray systems, which use only one line, require 3000psi.
Id like to use a pressure pot, but like the agility of the single wand.
What I do not want is a gravity feed or suction based gun. I want agility of the gun and wand, which you dont get when attached to it is a huge basin of material.
Husky from HD has something close... They have a suction version:
But what I really like is the non-suction blow gun, which is along the lines of what Im looking for:
Notionally I can play the NPT and fitting game to get the outlet to what I want so that I can use variable wands on that end.
But of course then the challenge becomes feeding the gun via the tank and hose.
Many pressure pots seem to show two hoses, one for air, one for material. The kind I want clearly does not:
Though most I see do:
This Astro unit, which takes two hoses, seems like a good deal, but again has that HVLP type gun which has a huge nozzle on the front, I believe for doing the mixing and atomization... While I want to be able to attach an additional wand or different nozzle to it...
So can anyone with experience spraying stuff share some of their knowledge and experience in this area?
Buying from corrosion technologies would be my preference, but $849 for what looks to me like a propane tank and spray gun is a bit much. If I can reuse one of my propane tanks and buy a gun and whatnot myself, it seems like a much better deal...
Thanks!
Thanks!
