My guess is that there is still fuel injected even after you lift off your foot from the accelerator, it just goes through the idle regulator. I read somewhere that if you want to save gas, wait till you almost stop before stepping on the clutch and disengaging the gear as no fuel enters the cylinders. Which is it?
Edit: this is on fuel injected engines.
