Originally Posted By: durallymax
Originally Posted By: roadrunner1
I am an advocate for adding fuel conditioner to every gallon of fuel.
The benefits are;
improving cetane
lubricity
moisture control
cold weather anti-gel (if applicable)
protects against corrosion
maximizes fuel economy
I have 9 different diesel engines, and every gallon of fuel is conditioned, without one injector failure or injection pump failure, I've never even had a fuel filter issue, they just get changed at whatever interval the manufacturer calls for.
I use the John Deere diesel fuel conditioner, its bottled by Stanadyne for them.
Stanadyne is the most trusted name in the diesel injection market.
The reason you have no fuel related issues is because you change at the OEM intervals. Those are rated very early especially on ag equipment because many farmers are lazy, don't think its important, wait till they're plugged or just wait until the end of the season.
On the topic of additives I'm a believer in none. A good fuel supplier is more important than any additive. If you get good clean fuel to start with you will be fine. With our current supplier the only fuel related issue we have had other than LB7 injectors which are not related, is the issue I'm fixing on a skid steer now, operators lost the cap and drove around bedding cattle for god knows how many days before someone else noticed it and said something. Tank full of corn fodder and sawdust now.
Additives cost far too much money for what they do in my opinion. If a component is going to fail it will fail. The older systems may not be designed for the newer fuel, but they do not operate under the same pressures and tolerances the new systems run at, thus they can withstand much more wear before an issue arises.
Its another thing you have to weigh your options. Throw money away every day, or gamble that you may or may not have a big repair bill.
I guess it all depends on how you are getting your fuel. Some of us have to deal with getting fuel from a lot of locations over several states. Not always a sure thing that you can rely on the retailer to make sure they didn't get a less than stellar load of fuel in their tanks. I regularly use a fuel additive, especially in winter. Having a diesel semi down at -10F along the road because of not taking a little precaution can be a mighty expensive lesson. Especially if the unit has to be towed into the shop. It costs $500 just for a tow truck to show up. I do always carry spare fuel filters, but there is always the chance that even that would not be enough. And with the way the hours of service are, along with just in time logistics, playing games for several hours along side the road is not a good thing. Prevention is lower cost. And for my diesel Jeep, I don't need the wife to have a fuel related problem going to town from the farm while I am sitting 600 miles away getting unloaded.
The benefits are;
improving cetane
lubricity
moisture control
