Gotta get access to a code reader/diagnostic tool that tells you more than which sensor is barking. Is it reading rich, lean, what? What are the fuel trims, etc. It could be a bad sensor upstream (engine temp, intake air temp, MAP, etc.) causing the computer to incorrectly trim the mixture, it could be a mechanical problem (injector, etc.) Need more info to correctly diagnose the problem.
