Originally Posted By: azsynthetic
Originally Posted By: gathermewool
What's not to get?
Why I run NEO 0w5 and ZMAX? Still clueless?
You can't quote partial statements, out of context
Ok, so maybe we need to break this down into parts:
1.
NEO 0W-5: This oil, based on the viscosity is an XW-20. Agreed or is there a question about this still? I have no opinion for or against this weight being used in your application. Still clear? Ok, so no questions on that one, right, and you understand that my only posts pertaining to this oil are to clarify its true specification?
I've given facts, not opinions, so what's your point of contention here? Again, to reiterate (maybe this will help; probably not): I don't care what weight oil you use. I'm interpreting the actual data and simply posted the oil's corresponding viscosity - no opinions involves, so clue or clueless, it matters not.
2.
ZMAX: Why do you think you need to run this? If you use Oil A, and Oil A does not meet your standard (be it personal or manufacturer-driven,) then a better oil is in order. At no time should an additive replace using a better oil.
You also claim that you want to thin out your "OW-5 oil." If you want to go thinner, then how about you start by choosing a thinner oil, for criminy's sake! This NEO oil (regardless of how much residual RL is still in there) does not appear to be a thin oil, let alone a 5W at 100C.
So, I dare you to respond meaningfully, instead of calling me clueless. The head of our nuclear training department once told me, "if you can't describe what you know to a dumb Idaho farm boy like myself, then you don't really know what you're talking about." So, if I'm clueless, then give me a clue. Otherwise, concede that you're simply doing what you want without any real reason for it.
I mean, Jesu Christo, your interpretation of being good to go is stating that the ECU hasn't bricked itself. You don't seem to have any idea how your mods are affecting your tune, nor whether the oil you're using is providing adequate pressure. Your engine may last another 300k, but it for darned sure won't be thanks to you!
