Small 4 Cycle Engines, longevity tips
by henni
05/29/16 10:05 AM
Car won't star after new serpentine belt
by AlaninPA
05/29/16 09:06 AM
Was this sold by Costco?
by Vikas
05/29/16 09:03 AM
Gas or lithium-ion powered string trimmer?
by skyactiv
05/29/16 08:41 AM
Tire pressure question
by Tlhfirelion
05/29/16 07:18 AM
So I did an oil change but didn't change the filte
by Tlhfirelion
05/29/16 07:05 AM
Mixing Mobil 1 0w20 with 5w30
by doublebase
05/29/16 06:49 AM
Max Life @ Menards
by scusemez28
05/29/16 06:24 AM
Cut Super Tech ST3980 2500miles
by jhellwig
05/29/16 12:25 AM
Smoked my first brisket today
by MrHorspwer
05/28/16 11:00 PM
Lowes charcoal sale
by Bandito440
05/28/16 10:17 PM
Jeepers Creepers! (Jeep Patriot)
by daves87rs
05/28/16 10:10 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
83 registered (901Memphis, 2015_PSD, AirgunSavant, AIRJAC3, 69GTX, 2004tdigls, 8 invisible), 1700 Guests and 137 Spiders online.
58013 Members
66 Forums
249553 Topics
Page 3 of 10 < 1 2 3 4 5 ... 9 10 >
#2864290 - 01/09/13 01:14 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: Clevy]
OVERKILL Online   content
Loc: Ontario, Canada
Originally Posted By: Clevy
So the oil thickening,is due to evaporation,or how does it get thicker?
Thanks
The oil may not be an xw-5 to begin with, I don't think the grade officially exists.
That being said, oxidation thickens an oil.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2864301 - 01/09/13 01:21 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: azsynthetic]
NateDN10 Offline
Loc: Rochester, NY
Do you know what the virgin specs are of this oil? Like previous posters have said, based on the 100C viscosity, this is an xW-20 oil.
Also, I can't find it listed on Neo's web site.
2005 Chevrolet Cobalt - 95,000 mi.
2012 Mazda5 - 80,000 mi.
#2864432 - 01/09/13 03:41 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: Clevy]
azsynthetic Offline
Loc: Phoenix AZ
Ha.
We really do split hairs on everything here,don't we.
So the lead is high but to be expected with such a thin oil and how you drive it. How much longer do we think it will last before the bearings have finally had it?
Lead is less than 1ppm per 1K miles so the bearing should last me another 300K miles at least.
#2864439 - 01/09/13 03:51 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: Brule]
azsynthetic Offline
Loc: Phoenix AZ
Originally Posted By: Brule
Originally Posted By: azsynthetic
My mileage went from annual average of 44mpg (48 max) when new to 57mpg (62 max) now with all the mods and the low viscosity oil.
What other mods have you done? How much of the mpg improvement do you attribute to oil viscosity?
You can see some of the mods in the engine pic. OMI intake, EGR deletion, DG race pipe, PCV vent to atmosphere, 3" straight exhaust, Aiken fuel box, advance injection timing, 205/70-15 tires, 2T fuel mix, and low viscosity oils. The low oil viscosity is good for 3-5mpg.
The Amsoil bypass filter took care of the soot and allows me to run non diesel oil.
Edited by azsynthetic (01/09/13 03:54 PM)
#2864448 - 01/09/13 03:57 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: azsynthetic]
3311 Offline
Loc: Fl
The "total oil used" is the correct term since we are dealing with UOA which by definition is "USED OIL" ANALYSIS. The UOA is not for top-off or makeup oil or originally fill only, it is for all the oil used. The UOA does not differentiate and it is the result of the "total oil used". Any oil added to the engine will become used oil, period.
What BITOG users assumed, misread, misunderstood, etc. are not my problems. I will always used the correct terms as defined by the process.
Maybe in the future just state "6 quarts intial fill and two quarts makeup". wink
What are you oil pressures wtih this viscoity? I asked this question once before.
Edited by 3311 (01/09/13 03:57 PM)
04 2500hd 6.0 278k/1k Pen HM 5w30 10w40 mix XG3675 VML ATF Dex
03 C7500 Dmax7.8l 134k ST 15w40,M1ATF Dex
06 2500hd 6.0 220k ? 5w30 ST DexVI PGL
#2864456 - 01/09/13 04:01 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: 3311]
azsynthetic Offline
Loc: Phoenix AZ
Engine ran fine in Arizona heat with no problem even when it was overheated. As long as I don't get a warning from the ECU I don't really care. I might thin it out even more with ZMAX in the near future.
#2864466 - 01/09/13 04:08 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: azsynthetic]
3311 Offline
Loc: Fl
Well since you don't care about the pressure, I will not either.
IMO, and I'm certainly not an expert, those are pretty high numbers considering you running a bypass system. I sincerly wish you luck though getting another 300k out of this engine.
#2864648 - 01/09/13 06:21 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: azsynthetic]
gathermewool Offline
Loc: New England
Thanks
Thanks
Based on the VOA/UOA #s, we know this oil didn't begin as an XW-5 - it's definitely on the thicker side of an XW-20.
The higher UOA KV @ 100C could be the result of oxidative thickening; however, the oxidation between virgin and used is very low, so another explanation could simply be inconsistencies between each bottle of oil. IN OTHER WORDS, the bottle of oil that the virgin sample was drawn from might have been thinner than than the average of all the bottles of oil added throughout this OCI. Just a thought.
Also, you're spending a lot of money on this oil - doesn't need any help (RE: ZMAX.) IMO, buy an oil suitable for the task at hand and let it do its job, by itself - no need for additives that may not play well with the oil's chemistry.
Edited by gathermewool (01/09/13 06:33 PM)
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#2864658 - 01/09/13 06:32 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: azsynthetic]
tig1 Offline
Loc: Illinois
I ask this once. Does this oil have the CL rating? If not what diesel rating does it have? Thanks.
2007 Ford Fusion 181,000 miles
M1 0-20 AFE
2007 Ford Focus 154,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2864877 - 01/09/13 09:23 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: gathermewool]
azsynthetic Offline
Loc: Phoenix AZ
Why do you even read this thread if this is what you believe in?
Why do I run 0w5 when practically any 5w40 will do? You just don't get it.
#2864878 - 01/09/13 09:24 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: tig1]
azsynthetic Offline
Loc: Phoenix AZ
API Service SJ/SH, ILSAC GF - 1 / GF - 2
#2864892 - 01/09/13 09:45 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: azsynthetic]
Loc: New England
Could you please explain what it is that I don't get? You've said that a couple of times thus far, but it makes less sense each time you type it, since you never explain your logic.
I'll say again that YOU'RE NOT RUNNING A 0W-5 OIL - your oil is an XW-20. Furthermore, no where did I say that you should run a thicker oil, either, so apparently you don't get it. It's ok if you don't understand something, but being combative to those on this forum trying help you is counter-productive. So, to answer your question: I'm reading and responding in this thread in reply to others mostly, not you, since you don't seem receptive to any advice or feedback.
Finally, I was simply giving you my opinion that a good, stout oil does not need the help of any additive, and that not only can some additives be a waste of money, but they can hamper the additive package of the high-dollar oil you're using. What's not to get?
Those specs are worth less than the label they're printed on, broseph.
Edited by gathermewool (01/09/13 09:49 PM)
14 Forester XT
08 Civic LX (Auto)
#2864902 - 01/09/13 10:04 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: azsynthetic]
spasm3 Offline
Loc: out there
LOL, something funny about that statement!
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#2864916 - 01/09/13 10:29 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: azsynthetic]
Clevy Offline
Loc: Saskatoon canada
Ha.
That's awesome. I admire you going a couple grades thinner and using your own vehicle as the test mule.
Do you know what the averages are with this engine using the vw spec grade oil. I doubt they could be all that much better?
2006 Charger RT
Miles x 2 per oil filter
#2864935 - 01/09/13 10:49 PM Re: NEO 0w5 Racing Synthetic, 25K, VW Golf 1.9TDI, ALH [Re: Clevy]
azsynthetic Offline
Loc: Phoenix AZ
Over in the TDI Club forum they have a thread listing UOAs. Many are worst than mine and at 10K miles or less.
