Antonin Scalia is dead
by skyactiv
02/13/16 05:04 PM
2003 Dodge Caravan rear wheel locked up
by Oldtom
02/13/16 05:03 PM
Kwik lift
by old1
02/13/16 04:55 PM
BJ's Mobil Super Synthetic on sale 6 qts/$22
by 69GTX
02/13/16 04:52 PM
Battery charging when its cold out
by Donald
02/13/16 04:48 PM
Alfa in formula one?
by Charlie1935
02/13/16 04:46 PM
2011 Nissan Sentra CVT Fluid Change
by LexAtlanta
02/13/16 04:07 PM
For Sale: 2004 Ram 1500
by RamFan
02/13/16 02:10 PM
2005 Volvo S40 2.4i - Optimal Oil Choice?
by mgm7890
02/13/16 12:58 PM
Something for a quiet Saturday, vapors...
by OneEyeJack
02/13/16 12:33 PM
Ford guys: Crown Vic windshield washer not working
by Jimmy9190
02/13/16 12:08 PM
Very cold outside, vehicle sitting for a few day's
by 07titan
02/13/16 11:26 AM
Formula413, Cruzingoose, klob, beaglefet, bsmith3
56907 Registered Users
83 registered (2015_PSD, 69GTX, Berny, BikeWhisperer, bbhero, 10 invisible), 1542 Guests and 100 Spiders online.
56907 Members
66 Forums
244653 Topics
#2863795 - 01/09/13 07:27 AM Oil Pressure Problem
kilkm68 Offline
Loc: Illinois
A friend of mine has an unusual oil pressure problem I never heard of. It's a new rebuild of an AMC 390 in a '69 S/C Rambler. When he accelerates his oil pressure goes DOWN. We checked with a different gauge and same result. Ran it a quart over full, still same result. A friend suggested maybe the screen came off the oil pump sump. Any thoughts on this?9
#2863827 - 01/09/13 07:56 AM Re: Oil Pressure Problem [Re: kilkm68]
Jim Allen Offline
Loc: NW Ohio
The screen is a good suggestion. Drop the pan ASAP. DOuble check gauge operation with a mechanical (unless that was how it was/is tested).
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#2863830 - 01/09/13 07:59 AM Re: Oil Pressure Problem [Re: kilkm68]
Trav Offline
Loc: MA, Mittelfranken.de
Could be a bad/broken bypass spring, slightly loose oil pump cover, bad pump to block gasket or the bolts might be loose.
Just a few things of the top of my head.
Edited by Trav (01/09/13 07:59 AM)
#2863908 - 01/09/13 09:08 AM Re: Oil Pressure Problem [Re: kilkm68]
mechtech2 Offline
Loc: Chicago Area
Just worked on my buddy's AMX with a 390.
I see fresh rebuild ,and a bad problem here.
Yank the pan and be anal about checking things. Of course, let the builder know NOW.
#2863917 - 01/09/13 09:15 AM Re: Oil Pressure Problem [Re: kilkm68]
440Magnum Offline
Loc: Texas
Excessive bearing clearances will do that, was this engine set up for racing with loose tolerances? Could also just be a measurement error and someone got the clearances too big.
When the engine is under load, there's a much larger net downward (away from the heads) force on the crankshaft than at idle or light load, which opens up the clearances on the oil feed side of all the main bearings and lets the pressure drop a bit. I've seen that on Mopar, GM, and Ford engines on several occasions. Normally increasing RPM offsets that effect and you never notice it, but if you're cruising with a more or less constant RPM and then apply throttle, before the RPM come up, the oil pressure may drop a few pounds. The real fix is to fit the main bearings better. May require undersize bearings... SHOULD require undersize bearings if the crank has been turned.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#2863945 - 01/09/13 09:38 AM Re: Oil Pressure Problem [Re: 440Magnum]
Brule Offline
Loc: St. Louis, Mo
That's what came to my mind, too. Because I did it myself on my first engine rebuild. Mine was accompanied by a knocking sound as well.
2014 Camry V6 SE (QSUD 5w20)
2003 Civic Si [sold]
2010 Frontier SE 4.0 [gone]
2006 BMW M Coupe [sold]
#2863992 - 01/09/13 10:01 AM Re: Oil Pressure Problem [Re: kilkm68]
TFB1 Offline
Loc: VA
My '69 428CJ Fairlane has that issue but it's because the oil will run away from the pickup upon hard acceleration, keeping it at least half quart over full solves the problem... No doubt needs a deeper sump pan, but I want to keep it original... It's made 44 Years and 107K mi, so I ain't messin' with it...
#2864033 - 01/09/13 10:31 AM Re: Oil Pressure Problem [Re: kilkm68]
OB4x4 Offline
Loc: sc, usa
If you have oil pressure at idle and no pressure once you accelerate you may want to check the pickup to pan clearance. Too little clearance will cause the pump to cavitate due to the oil not being able to flow in between the two rapidly enough.
00 toyota tacoma 3rz 181,000 mi
m1 5w-30 (5-7k mi oci), mt90, m175w-90.
08 scion xb 2az 70k mi.
m15w-20 (5k mi oci), idemistsu tls-lv
#2864097 - 01/09/13 11:22 AM Re: Oil Pressure Problem [Re: kilkm68]
TallPaul Offline
Loc: By Detroit
If the rod big end bearings are too lose, they will leak oil. When you increase rpm they will leak more. Maybe that's it. Maybe something else as mentioned above.
The masses, thirsting for convenience, unwittingly dig the grave of the automobile as we knew it. The industry already has one foot in that grave.
#2865224 - 01/10/13 09:25 AM Re: Oil Pressure Problem [Re: kilkm68]
SS1970chrysler Offline
Loc: PA
My '79 Thunderbird w/351 Windsor did that around 102k miles. The oil pump was shot and rear main bearing was out of tolerance.
93 Towncar- Rotella T5 10w-30+M.Craft
93 CrownVic- QSGB 10w-30+M.Craft
78 LTD- S.Pro XHD30+ProTec
