When Is "Too Old" To Drive????
by qwerty1234
06/01/16 01:02 AM
Where do peanuts come from ?
by Merkava_4
06/01/16 12:58 AM
Subaru V-twin engines
by oil pan 4
06/01/16 12:25 AM
Napa June 2016 sale 6/1-6/30
by slacktide_bitog
05/31/16 11:42 PM
Castrol SAF Carbon Modified SAE 75W/85
by ABomb369
05/31/16 10:44 PM
any harm done to Ranger?
by mobilaltima
05/31/16 10:17 PM
Obsolete Freeway on ramps
by jimbrewer
05/31/16 10:14 PM
Ideal-Tridon Hose Clamp Display
by Merkava_4
05/31/16 08:52 PM
Want to hear from turbo owners that go 10k + oci
by Sw296inchblue
05/31/16 08:31 PM
When you have found the right combo
by bbhero
05/31/16 08:25 PM
High Mileage diesel oil?
by Hysilver
05/31/16 08:23 PM
Barium
by Hullthumper
05/31/16 07:25 PM
alex_at, AudiTDI, Denisdog, bcs4, Bart_B
58036 Registered Users
28 registered (BigD1, bbhero, crazyoildude, Atesz792, cwing6, 69GTX, 2 invisible), 541 Guests and 99 Spiders online.
58036 Members
66 Forums
249652 Topics
Page 1 of 2 1 2 >
#2862365 - 01/08/13 04:47 AM Kreen in the oil... ?
GearheadTool Offline
Loc: Boston, MA
How long would YOU leave (8oz, 12oz, 15oz, 32oz) KREEN in for? 10 minutes? 20? 30? 1000 miles? 2000? .....
And, would you add it to a HOT engine, or COLD?
Just asking because I heard it is really good. Also, more effective if you put half in the gas, a la Seafoam... ?
"Listen, Walter, just because you shot Jesse James... don't make you Jesse James."
2000 Volvo V70 XC AWD - 138k mi. - SOLD! 2/16/03, Redline 0W-20
#2862372 - 01/08/13 05:06 AM Re: Kreen in the oil... ? [Re: GearheadTool]
linkbelt Online   content
Loc: Tn. mountains
I am using one pint of Kreen, (1999 Subaru), in the last 1000 miles before I change oil/filter.
I will do this once more, then I am done, clean or not.
#2862378 - 01/08/13 05:23 AM Re: Kreen in the oil... ? [Re: GearheadTool]
LeakySeals Offline
Loc: MA
1/2 pint of Kreen the last 1k before oil change every 2 years/30k. I tried Kreen in the gas, followed by a PEA additive in the gas for an occasional rough idle/misfire issue. Gone with the PEA gas additive, has not returned. So I use a 10oz Walmart bottle of techron concentrate plus the last 1/2 tank of every 7k OCI.
02 Camry XLE 2AZ-FE 348k M1 HM 5w30
06 Escalade 135k. M1 5w30
#2862418 - 01/08/13 06:50 AM Re: Kreen in the oil... ? [Re: GearheadTool]
Phishin Offline
Loc: Indiana
Putting Kreen in the gas is a waste of Kreen, I think.
Depending on your engine dirty problem, there are lots of "ways" to Kreen your motor.
I had success in my truck dumping in 1 quart for 1000 miles. Changed oil. Then ran a pint for a 1000 miles at the end of the next two OCI's.
I like to dump in in the engine cold. Kreen is pretty volitile. I'd hate to dump it in and have a good portion of it flash off in the bottom of the oil pan. That's just me tho.
2010 Accord-LX K24: PU 5w30
2009 Subaru Forester 2.5X: M1 TDT
1990 Chevy K1500 350TBI: Frankenbrew
2008 Ruckus 50ccGET: M1R Mix
#2862453 - 01/08/13 07:26 AM Re: Kreen in the oil... ? [Re: Phishin]
Clevy Offline
Loc: Saskatoon canada
I don't see how this would be a good idea. Every additive I've ever see directions on says to add it to a hot running motor.
How exactly would it flash? Are you suggesting there is no oil in the pan while the engine is running?
Ght. You will have the cleanest Volvo engine on the planet that has chipped pistons and bent valves. But it will be clean,as it heads down the road on a tow truck en route to the auto wrecker.
With all these threads you've started showing us all your purchases and such,I wonder if you added it all together you would have enough to change that timing belt by now.
Just a thought.
2006 Charger RT
Miles x 2 per oil filter
#2862499 - 01/08/13 08:02 AM Re: Kreen in the oil... ? [Re: Clevy]
Loc: Boston, MA
Just a thought.
Clevy, can you tell me more about the chipped pistons and bent valves? I don't know anything about how those things get that way, is why I am asking!
I think the T-belt is coming when it is Inspection time. I have a feeling.
I don't do this EVERY day... (Italian Tune-Up)
#2862572 - 01/08/13 09:07 AM Re: Kreen in the oil... ? [Re: GearheadTool]
-SyN- Offline
Loc: Tornado Alley
That looked pretty dang dangerous!-->{Filming that} I always thought an ITU was a handfull of hard runs from 60mph to over 100mph and beyond. Guess I watch to much Top Gear!
14 Ram 5.7L->PUP 5W-30 & SRT 0W-40 Combo!
08 Ford F150 FX4-->Castrol 0W-40!
12 Ford Edge-X2 Limited & SE->PP 10W-30!
#2862608 - 01/08/13 09:36 AM Re: Kreen in the oil... ? [Re: GearheadTool]
Artem Offline
Loc: Florida
I think it's best to follow the manufacturers recommendations that are printed on the bottle. Someone recommended 3oz per quart of oil. I've been adding 12-15oz of Kreen to my 98 Toyota Camry V6 that's going through a Kreening process.
I started with a fresh fill of oil and added 12oz. 1,000 miles later, I added 15oz. I'm now nearing 3k on the fill and don't know whether to dump the oil or add more Kreen and run it some more....
2015 Lexus ES300H with all the goodies - Factory Fill
2014 Mazda 3 Hatch i Touring 2.0L & 6spd - Mazda 0w20
#2862622 - 01/08/13 09:42 AM Re: Kreen in the oil... ? [Re: Clevy]
Phishin Offline
Loc: Indiana
[quote=Clevy
Just a thought. [/quote]
Clevy....you missed my point.
When I say flash, I mean, the Kreen has a very low boiling point...meaning, it's volitile. So, dumping Kreen into hot engine oil would cause it to vaporize (ie, NOT stay in the oil).
I want the Kreen to stay in the oil for as long as possible. Which isn't very long under normal driving conditions. I want the Kreen to stay in the oil so it cleans out the areas of the engine that are in contact with dirty oil and sludgy crud.
However, I do think some vaporization is helpful. It will help clean the intake and the PCV system because of this, which is a positive side effect. But I want the majority of my Kreen to be in the oil to do it's cleaning.
If you dump Kreen in cold engine, and go for a 3-400 miles high way drive, most of the Kreen has probably gone out the tail pipe when you get home.
#2862693 - 01/08/13 10:35 AM Re: Kreen in the oil... ? [Re: GearheadTool]
demarpaint Offline
Loc: NY
I add Kreen to a cool engine, fire it up and drive. I remember back in the day, people would heat up a bottle of STP, and pour it into a hot running engine making it easier to pour and mix better. I don't see the need to do that with Kreen. Opinions vary.
God Bless Our Troops
#2862737 - 01/08/13 11:17 AM Re: Kreen in the oil... ? [Re: Phishin]
Loc: Boston, MA
I'm not sure V has gas for 3-400 miles!
So, now I am thinking to put it in a HOT engine, since I really wanna clean the PCV?
#2862738 - 01/08/13 11:19 AM Re: Kreen in the oil... ? [Re: -SyN-]
Loc: Boston, MA
There was one time I did that, I heard sirens in the tunnel. ........
Yeah, I have to say.. Getting everything REALLY hot/circulated/you hear that turbo spool, sometimes blow off its boost, and tires chirp because you took a turn real hard.. THAT is an IT-U. Top Gear.. is a snoot British show, and the American version is so bad...
Maybe you are talking more about runs like this? (I have been cutting down on how often I do this.. But, I have to say: The car likes it, and runs better afterward. I honestly think I am "blowing out" something that isn't supposed to be there.)
#2862771 - 01/08/13 11:54 AM Re: Kreen in the oil... ? [Re: GearheadTool]
Phishin Offline
Loc: Indiana
It will clean the PCV when the engine gets out and the Kreen begins to become gaseous/vapor.
#2862784 - 01/08/13 12:10 PM Re: Kreen in the oil... ? [Re: GearheadTool]
demarpaint Offline
Loc: NY
It will get hot once you start driving flash off and clean the PCV system. Honestly I don't think adding to a hot engine or a cold engine will matter, if anything adding to cold engine is probably safer.
#2862811 - 01/08/13 12:32 PM Re: Kreen in the oil... ? [Re: GearheadTool]
electrolover Offline
Loc: TEXAS
I dont think it really matters when you put it in but I like to drive the car right after I put it in to make sure it gets mixed in the oil. Dont worry about how long because it will evaporate after 500 miles or so
2004 F150 5.4 160k-Castrol TXT 5/40, Distance+ 3410-KREEN
2004 Explorer 4.0 130k-PU 5w30, Distance+ 3410
Page 1 of 2 1 2 >
