I've heard that you use methyl hydrate in your gas if you want to pass emission test with flyin colors.. but the contration I heard to use was close to 1:3 of gas to methyl hydrate to accomplish this.. Is this true? what happens if it's only quater tank mix?? Will there be adverse affect?
I heard it's the same thing as Methanol whic is basically gas line anti-freeze..
secondly.. is it good to run this thru the tank as a regular oil change interval kinda thing? Like Naptha ( fuel injector cleaner before an oil change )
