Long time lurker, finally registered and this is my first post. I wanted to share the results of how my 2004 Volvo S60 is handling the switch to Red Line and my extended drain preferences. Couple of notes:
* Sump capacity is 6 quarts
* Oil Filter is Volvo OEM (Mahle)
* Make up oil is 1 quart, but half of it was added very shortly after the oil first went into service. The other half was added at appx. 6,000 in.
* Blackstone had incorrectly listed the engine as a turbo in my previous UOA which I asked them to correct to normally aspirated as you can see in the comments.
* Vehicle is a 5 speed manual, also using Red Line MTL.
* Previous fill was M1 0w30 AFE - I will post this UOA in case anyone is interested.
Blackstone: Thanks for the notes, and sorry for the mix-up with the engine type last time. Luckily, the universal
averages for Volvo's 2.4L engine and the 2.4L Turbo aren't all that different. These averages for the
non-turbo 2.4L engine are based on ~5,700 miles of oil use, so your numbers are in great shape after a
much longer oil run. Even iron is better than average on a per-mile basis. The TBN of 0.5 shows that the oil
was nearly out of active additive, so it was a good time to change the oil. It looks like 10,000-11,000 miles is
going to be a good interval for you. Nice!
Code:
OIL Red Line 5W-30
MILES IN USE 10,245
MILES 126,081
MAKE UP OIL 1 QT
SAMPLE TAKEN 11/20/12
ALUMINUM 2
CHROMIUM 0
IRON 17
COPPER 2
LEAD 0
TIN 1
MOLYBDENUM 576
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 7
BORON 32
SILICON 14
SODIUM 19
CALCIUM 2821
MAGNESIUM 149
PHOSPHORUS 1123
ZINC 1028
BARIUM 0
INSOLUBLES 0.3
WATER 0
FUEL
ANTIFREEZE 0
INSOLUBLES 0.3
FLASHPOINT ºF 410
SUS VIS 210ºF 61.7
cSt @ 212ºF 10.7
TBN 0.5
Overall, I am happy with these results, same oil went back into the sump this time around and I will stick to a 10k change most likely. Considering Red Line 0w30 next time around.
Questions / comments welcome.
Thanks,
Shawn
Code:
OIL Red Line 5W-30
MILES IN USE 10,245
MILES 126,081
MAKE UP OIL 1 QT
ALUMINUM 2
CHROMIUM 0
IRON 17
COPPER 2
LEAD 0
TIN 1
MOLYBDENUM 576
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 7
BORON 32
SILICON 14
SODIUM 19
CALCIUM 2821
MAGNESIUM 149
PHOSPHORUS 1123
ZINC 1028
BARIUM 0
INSOLUBLES 0.3
WATER 0
FUEL
ANTIFREEZE 0
INSOLUBLES 0.3
FLASHPOINT ºF 410
SUS VIS 210ºF 61.7
cSt @ 212ºF 10.7
TBN 0.5
Thanks,
Shawn
