A Story Worth Living
by LoneRanger
05/06/16 05:37 PM
Snake Oil Detergent - 0.37 Cents
by Greg L
05/06/16 04:35 PM
Wax for silver car
by 007
05/06/16 04:32 PM
Trump's empty picture frames
by SumpChump
05/06/16 04:05 PM
Is 0w40 slightly Thicker than 5w30?
by Greg L
05/06/16 03:53 PM
Keep it simple.
by JustinH
05/06/16 03:28 PM
Pennzoil Ultra Platinum, 5W-30, 5k OCI, 20k total
by Joshua_Skinner
05/06/16 02:26 PM
Amsoil 75w90, 45K, 04 Chevy Tahoe
by dhellman12
05/06/16 02:09 PM
What happened to this kind of oil change?
by OneEyeJack
05/06/16 01:44 PM
OH! OH! Gas/Diesel mixup
by azjake
05/06/16 01:09 PM
VOA Pennzoil Platinum Euro 5w40 - SN
by agpatel
05/06/16 12:36 PM
VOA Liqui Moly Leichtlauf High Tech 5w40
by agpatel
05/06/16 12:30 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
87 registered (AZjeff, 2015_PSD, AirgunSavant, AUTOTECH89, A_A_G, 8 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248555 Topics
#2859071 - 01/05/13 10:56 AM Wisconsin V-4 Oil.
Deere John Offline
Loc: Montana
I'm in the process of getting the exhaust valves unstuck in an Wisconsin V4 industrial engine (just got it last week) From the info from Wisconsin site states 30w or 20w but info is from the 1980's. Is there a modern 10w-30 that will work? Since its air cooled and runs hot would like to use a 5-40 or 15-40 oil any experts with these older Wisconsin's. Thanks
#2859141 - 01/05/13 11:43 AM Re: Wisconsin V-4 Oil. [Re: Deere John]
jeepman3071 Offline
Loc: Storrs, Connecticut
I'd use a heavy duty engine oil like Rotella T5 10w30. Those Wisconsins are great engines. Be sure to post pics of it! thumbsup
2000 Jeep Cherokee Sport 4.0L (163k) - Pennzoil HM 10w30, Napa Gold 1516, Magnefine trans filter
#2859195 - 01/05/13 12:36 PM Re: Wisconsin V-4 Oil. [Re: Deere John]
Donald Offline
Loc: Upstate NY
What is causing the exhaust valve to be stuck? Rust?
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2859265 - 01/05/13 01:39 PM Re: Wisconsin V-4 Oil. [Re: Donald]
Kruse Offline
Loc: Kansas
I've got two of these engines. I'll be looking forward to the reply back from the OP, but remember that these engines were probably built in the 50s or 60s, run hot because they are air-cooled, have a tendency to vapor lock because the carb sits in a hot spot and have a tendency for the head bolts to seize to the head. They also need to have all air shields in place and the dirt must be blown out every day.
On the bright side, parts are relatively cheap if you are patient and get them through ebay sellers cleaning out their NOS stock and the fuel pumps can still be purchased through NAPA. (That's what the ebay sellers are doing. They sell a fuel pump at a rediculously jacked-up price and then order it at the local NAPA really cheap AFTER the sale is completed on ebay)
To the OP, if these engines are parade queens, any 30W will work. If they are run hard, use a good 15W-40 synthetic that still has some zinc in it. Remember that oil technology has come a long way since the operator/maintenance manuals initially came out.
Edited by Kruse (01/05/13 01:40 PM)
#2859271 - 01/05/13 01:43 PM Re: Wisconsin V-4 Oil. [Re: Donald]
Deere John Offline
Loc: Montana
Don't think it was rust as exhaust points down (not up like on a hay bailer),Cleaned out under shields and found a mud wasp nest-- maybe cooling. I am using ATF & acetone (50/50 did try several others like Kroil etc but ATF seems best) to loosen ex valve, Was running on 3 cyl with no compression in #4. Just about have it free enough to start.
#2859281 - 01/05/13 01:53 PM Re: Wisconsin V-4 Oil. [Re: Kruse]
Deere John Offline
Loc: Montana
Mine has a electric fuel pump (after market) It has no engine tag so not sure of model. It does has alloy heads which makes it newer,expect it to be about 35hp as its in a smooth drum road roller, working Hobbs meter states 256 hrs.
#2859541 - 01/05/13 06:30 PM Re: Wisconsin V-4 Oil. [Re: Deere John]
Blaze Offline
Loc: Washington State (East)
I believe most hay baler applications used the 36 hp model. You can still get the Wisconsin engine on the Freedom hay balers.
#2859746 - 01/05/13 09:38 PM Re: Wisconsin V-4 Oil. [Re: Blaze]
Deere John Offline
Loc: Montana
On the Wisconsin site the have new OHV V4's that make a lot more HP + more $.
Here's some info from Wisconsin site .
Thank you for visiting Wisconsin Motors, LLC on the internet. We build gasoline, LP and NG fueled, air-cooled and water-cooled engines. Our product offering ranges from 9hp to 72hp . Our unique product offering, addresses a specific and valuable niche in the market place.
#2860408 - 01/06/13 03:36 PM Re: Wisconsin V-4 Oil. [Re: Deere John]
46Harry Offline
Loc: hawthorne, Ca.
I maintain a manlift with a Wisconsin VH4D engine in it and I use Chevron Delo 400 15W-40 in it and getting good service from the oil. The engine lives in Chino, Ca, so it gets up into the low 100's in the summer and around freezing in the winter. I decided that the 15W-40 is a good all year oil for the engine.
#3222230 - 12/20/13 12:46 AM Re: Wisconsin V-4 Oil. [Re: Deere John]
JR Offline
Loc: Michigan born but my heart bel...
Growing up on the farm we had a v4 powered bobcat. I cut my teeth in that old cat. grampa ran pennzoil at the farm. we stock pyb 5/10w-30 and long life 15w-40. we haven't used it much in the last few years since grampa past and we got out of angus feeders.
Ken
#3226029 - 12/23/13 10:23 PM Re: Wisconsin V-4 Oil. [Re: Deere John]
JR Offline
Just serviced the bobcat couldn't find pennz 15w-40.
My uncle serviced it with delo synthetic 5w-40 with redlin break-in additive added, k$n filter.
ken
#3271490 - 02/05/14 03:10 PM Re: Wisconsin V-4 Oil. [Re: jeepman3071]
camelCase Offline
Loc: Southeastern, USA
This. Rotella T6 is what i'd go with. It's a little thicker on the upper end (40 vs 30), yet thinner in the bottom (5W) so you can help mitigate some startup wear. Plus, you're tolerances aren't "as new" anymore, so a little thicker viscosity will help reduce wear a bit.
The diesel formulation oils have more detergents and such to help control soot and other particulate. I recommend them for any ICE running diesel or forced induction.
