Originally Posted By: Kamen
I just purchased a Subaru Outback XT, with the 2.5L turbo engine, which is notorious for having the turbo charger overheat. The direct reason is the oil starvation caused by clogged inline screens in the oil supply lines leading to the turbo. The latter being caused by infrequent OCI. The previous owner believes they have changed the oil regularly, but they have kept records and in those records there are two lapses of over 10,000 miles.
While I am getting some advice at the LegacyGT forums, I was referred here for oil-specific questions. I had an engine oil analysis done and the results are posted here:
The concern is that if the oil running through the turbo is mostly used for cooling and not lubrication (couldn't get an answer to that), then any wear on the turbo shaft would not be reflected in the test results. However, while I plan to inspect those inline screens, I am wondering if I should do an engine flush, and if yes - what product and procedure is recommended here?
Kamen
Good to hear the rest of the posters saying don't flush, as that is the best answer. The UOA looks real good although there are no universal averages listed and it would be interesting to know which oil and OCI the UOA was for.
If the turbo goes bad it will probably show Cu and Fe and 2ppm of Cu is nothing to be concerned out. Bad turbos nearly always start to drip oil after high RPM use, so if it looks clean underneath it is probably OK.
The forum chaps will know more than most about this engine, but it sounds like a major brand full synthetic that has lots of Calcium detergent and Boron dispersant compounds will help keep the engine clean. If you change that type of oil every 5K miles (Check the Subaru service schedule for the OCI, as the oil filter might be good for 10K miles) and don't sit in traffic jams or go off roading in dusty conditions the engine will stay clean (The UOA does not list an insolubles figure for some reason).
If you do get definite evidence of a potential sludge issue, like the oil turning black immediately after an OCI, the oil pressure warning flickering at hot idle after a high RPM run (Serious) or lumpy stuff in the old oil (Even worse), then get the sump removed to see how bad the problem is and clean it out along with the oil pump feed screen. If it's bad then unfortuntely the head will need to be removed for a major cleaning job.
I might be known by some as an anti snake oil type, but I regard idle only flush oil additive as a safe maintenance product. The two brands that seem to be of the best quality are Liqui Moly and Amsoil, probably because they are real engine oil companies. You add the flush just before the OCI and let the engine idle for 10 or 15 minutes and then change the oil and filter. This is the link to the data sheet:
IDLE FLUSH
Watch the oil pressure light during the 10 (LM) or 15 mins (Amsoil time) the engine is at idle and NEVER DRIVE AROUND WITH FLUSH ADDITIVES IN THE OIL. These types of oil additives are safe because even if the oil filter blocks or the turbo feed line got obstructed as 10 mins at idle will not do any damage to the engine.
I will now take cover before some chap says poor a can of Moo oil in and drive around for a few weeks, don't even think about it!
