I have an Aprilaire 550 flow-through humidifier connected to my furnace. I believe it's 20 years old and was installed when the furnace was.
Today I noticed how much water seems to be wasted. A LOT of water drains off the pad, out of the unit, and down the drain. I don't think it's doing anything different, but was just something that I happened to notice.
For those of you that know something about furnace humidifiers, is this normal? Or could the solenoid valve be letting way too much water through?
Other than replacing the pad annually, I haven't done anything to it. Poking around Aprilaire's website, I see a maintenance kit that includes a feed tube with a new oriface. It also includes an in-line strainer which mine doesn't have. I wonder if that just strains large particles out of the water or if it restricts the flow too.
