I went to this quick lube place, they did a transmission fluid flush and put in Dexron III.
I came back home and found my 2009 Mazda6 3.7L V6 requires JWS 3309 fluid, so I called them up.. they said they added Dexron III plus some friction modifier to make it compatible with Toyota T-IV fluid (and T-IV fluid is same as jws 3309 fluid)
Is that true? or should I flush my transmission with jws 3309 ASAP??
