Over Oiling
by mjoekingz28
06/27/16 12:59 AM
Sweden Trials Electric Higway for Trucks
by Y_K
06/27/16 12:07 AM
17 yo deutsch filter?
by robo339
06/26/16 11:07 PM
Ford Focus wrecked
by tig1
06/26/16 10:13 PM
Valvoline Maxlife vs Supertech Synthetic vs QSED
by mazdamonky
06/26/16 09:56 PM
Lexus seats in a Camry
by Nick1994
06/26/16 09:52 PM
shop rechecking work after front end parts replace
by motor_oil_madman
06/26/16 09:50 PM
M1-EP vs vanilla M1
by Atomic
06/26/16 09:29 PM
Supertech Synthetic and Citgo
by RRLJR
06/26/16 09:28 PM
Gun Belt Wanted
by FirstNissan
06/26/16 08:24 PM
car wash soap for pressure washer
by Donald
06/26/16 08:16 PM
Deep tranny pan worth it?
by rsylvstr
06/26/16 07:20 PM
Josh_Westwood, Brogan, Superlatives, Ruturaj, derfderfgoose
58280 Registered Users
26 registered (CR94, bbhero, Chewie, DeafBrad, 76sixer, Boczech), 1091 Guests and 16 Spiders online.
58280 Members
66 Forums
250854 Topics
Page 2 of 2 < 1 2
#3066278 - 07/15/13 04:54 PM Re: Duece and a half [Re: ridgerunner]
2cool Offline
Loc: Delaware
The engines in the olde Truck, 2 1/2 ton, 6X6, M-48, were compression-ignition engines designed by M.A.N. (Machinen fabrik von Augusburg und Nuernberg) built under license for the Army by Mack, Continental, White, and Hercules. The pump was a Bosch single piston distributor type, where the fuel lines from the pump to the injectors looked for all the world like reallly long spark plug cables. As the fuel entered the pump, it went through the Fuel Density Compensator. The density of the fuel would cause an adjustment of the quantity of the fuel injected, and change the injection timing. The theory was that the denser the fuel, the more energy. The denser the fuel, the more time it would take to burn.
IIRC, the Technical Manual called for 1 Qt. SAE 10 oil per 10 gallons of gasoline, just to lube the pump. It would get much lower mileage on gas, but it would go. I believe that even with a turbo, the output was 130 hp. But then the Army only planned on it going 35 mph in line-haul style operations.
#3358955 - 05/01/14 02:42 PM Re: Duece and a half [Re: ridgerunner]
ironman_gq Offline
Loc: MN
The old ones would run on just about anything because the injection systems were a lot more robust and simple. The old injectors were just a poppet valve with a nozzle on one side, it fired once per compression cycle and didn't need to be too terribly precise in metering fuel. Same with the pumps, they ran at a couple thousand psi at most, The new fuel systems on these trucks are using electronically fired injectors that can fire 4-5 times per cycle and pumps that operate at 30 thousand psi. To do that everything must have very precise tolerances, a change in fuel viscosity or a little debris in the fuel and the whole thing falls apart and parts get damaged.
Page 2 of 2 < 1 2
