Originally Posted By: volk06
Originally Posted By: KCJeep
Yes they do. UOA's are indicating that Mobil Super has about 30 ppm of titanium additive, which is an anti-wear additive.
For comparison, Kendall uses nearly triple the amount of titanium over Mobil. Castrol Edge FST, Castrol's top oil, also uses titanium of about 30 ppm but their titanium is apparently somewhat different, as Castrol advertises it as "patent pending".
If you review UOA's, so far the results with oils using titanium have been very good, and many users have claimed better fuel mileage as well. Ironically Mobil Super is both a syn blend and has titanium in it, and Mobil advertises neither feature that I know of.
Titanium is thought to possibly be a low cost alternative to moly, although it apparently works very well, I find it interesting Mobil does not use it at all in their premium Mobil 1 line up, just the valued priced Super. But you can't argue with results!
Mobil Super is a regular conventional via pds
Mobil Super HM is a blend - states it on the back of the jug and on the pds.
Yes you are right my mistake too late to edit though, thanks!
