Hi guys. I was messing with some wiring earlier and now have a 3-way switch that trips the breaker. Maybe you can help?
I was messing with a 15-amp circuit that has a bunch of stuff on it including a smoke detector and doorbell transformer, both of which are down in the basement. A Black/White/Ground wire ran to the smoke detector, then to the doorbell transformer, and from there to the 3-way switch.
I removed the smoke detector and doorbell transformer and ran the Black/White/Ground wire (that previously went to the smoke detector) directly to the 3-way switch. I **believe** I connected it just like before, but now it causes the breaker to trip when I switch it. Everything else on the circuit is functioning fine.
The switch is a standard 3-way Leviton from Home Depot. The red wire from the other wire that runs to the box is connected to the same copper-screw terminal as before. Same with the black wire. In fact, those were never disconnected. The white wire was coupled with the new one, as were the ground wires which were then reconnected to the switch. The black wire from the new wire was connected to the black-screw terminal, which is where the old black wire was connected.
Given that everything else on the circuit is working, I'm guessing I just have something with this switch messed up and despite going over it again and again, can't find what I did wrong.
