I have a newly acquired 1951 Farmall M that I will be using in antique tractor pulls next year. It is slightly modifed (cam, larger pistons, sleeves removed, governor tension reduced for higher rpms) other than that it is stock.
My question what should I run for oil? I run M1 in all my other vehicles and really like it. However since M1 is not available in a SAE 30, not an option. SAE 30 is what the manual for this tactor recommends and I also think it would be better due to this tractor never really getting up to operating temperature as a puller, short runs and it will never do farm work... Also will never be ran in cold weather. So in this case is straight weight better than multi? And which synthetic? Price is not a concern. Thanks
