The only cases of common rail HPFP failures have been put down to using cheap supermarket fuel.
I personally always used high quality BP, Esso or Shell fuel in my Mondeo tdci and in my V50.
Wife uses cheap stuff despite my protestations and she has some injector noise.
I do dose it with Redex at oil change time and sometimes 2 stroke oil.
The Mondeo tdci was well know to have HPFP issues especially in the 130bhp version that I had. Well I owned it from 80k till over 220k and my mate traded it in with 250k plus recently.
I only cleaned the EGR valve once at about 150k and it ran aswell when sold as when bought over four years earlier, actually was stil returning 54mpg with my mates usage.
I personally think the fear of failure with common rail fuel pumps is over rated, I never heard of one pump failure with the 2.7 Sprinters at work, again they were only ever run on BP as the service had a contract with them, as did the Met Police.
Since the introduction of the CR engines in the Passat it is now much more reliable. To the extent that most people avoid the non CR.
I would use 2stroke at a 200:1 ratio a d use decent diesel.
Don't forget that was good enough for Mercedes on an expedition to, I believe North Africa or Mongolia a few years ago, to protect the engine and fuel system from lower quality fuels.
I also understand why they didn't widely publicise it.
But I also advise my inlaws in Ghana to use 2 stroke in all diesel vehicles, so far no issues.
