Yes, MAP not MAF.
I agree with phishin that the ECU is bad....the timing never acts the same way twice. Last night I started it.....fired right up and idled smoothly....revved a few times and again, bogged down, backfiring and the timing mark, with the est wire connected is all over the place but is staying primarily near zero....it does move when you increase throttle but moves the wrong way, i.e. less advance to after dead center (which could also be the rubber slipped on the damper).
The ignition module has been replaced. Remember folks, this problem started all of a sudden and I think the engine damage was caused by continuing to drive it while acting up. I'm really surprised he was able to drive it at all.....I can't get it to pull my driveway without backfiring and bogging down....exactly like the timing is off....which it is.
The price of the ECU at AA is very reasonable so once I get the original number, will order it today.
