1994 1500 5.7 TBI (3 year old Jasper engine - 20k miles).
Background;
Grandson drove truck 75 miles to my place backfiring and barely running. Truck had been overheated several months prior and I assume it was HOT. CTS was not grounded and apparently fuel-washed the cylinders...several shots of oil in cylinders brought compression back except for #1. Removed head...machine shop found valves warped badly:::bought two reman heads and installed.
Today;
put back together, checked cam timimg and set ignition timing to 0. Started and ran a little rough but not bad. Set timing with light after disconnecting wire at dash and again timed to 0. The truck was running perfectly in the garage for 35 minutes, revving and idling fine...pulled it out to do a road test and revved a few times and blam, backfiring, won't idle. Truck was at a slight downhill angle so I'm wondering now if I'm also dealing with bad fuel. Attempts at starting now result in absolutely no power when it does start, won't respond to accel, backfiring. If I keep playing with it it seems like cylinders are coming back on-line and then dropping out again. Both cylinder heads were a mess though with numerous warped/bent valves. The m/shop did not have a favorable attitude towards Jasper.
Any ideas folks? I'm really frustrated at this point especially since it was running two hours ago perfectly. Compression after head replacement is at 140.. Cylinder walls show good cross-hatch.
Background;
Today;
