lol, my 240, which has 73k and is like new, shakes far more, and is noisier than any 617.952 equipped car that I have owned. The 300D cars also have more sound deadening, IIRC. And on the highway, the RPMs are far different, which makes a huge difference too! [/quote]
Nice to see forum members driving classic MB's. As for the shaking you might want to check your motor mounts. It's a common problem for all of these cars. When was the last time you adjusted the valves? Also, some injectors seem to work better than others especially when properly balanced. What ever you do please do not return you core Bosch injectors to the dealer. New bosch injectors are coming out of India. Keep your injectors and get better nozzles. You might already be a forum member at benzworld.com or peachparts.com but if your not you might want to join. I own a w116 300sd and a w108 280sel. I use Chevron Delo 15-40 and occasionally Shell Rotella 15-40 on my w116. Without oil analysis you really cannot say how long you should run the oil for so I would stick to the 3,000 mile interval. To say that one oil is better than the other is a hard thing to say without concrete evidence such as oil analysis ON YOUR CAR. Too many variables inside that engine to even conclude that just because your analysis shows great results that now such oil will react the same way in a different car or even the same model. Keep an eye on oil levels and give different oils a chance to see how they work with YOUR ENGINE. Some oils seem to work terribly inside my w116 and I get tired of adding quarts and quarts before changing the oil at around 3000 miles. Other oils APPEAR to work fine and adding oil between oil changes is not needed. Try oil analysis if you really want to know whats going on with your oil.....Your oil filter is also important. I use Baldwin, Napa Gold(wix) on my Chevy and Honda Civic and use Mann on both my Mercedes Benz....This is not a recommendation, these are the filters and oils that I use
