Just read this on wikipedia :
Quote:
In the U.S. and Canada, a vacuum flask is used to store hot coolant when the vehicle is powered off for reuse so as to reduce warm-up time. The Prius engine makes use of the Atkinson cycle.
When the vehicle is turned on with the "Power" button, it is ready to drive immediately with the electric motor, while electric pumps warm the engine with previously saved hot engine coolant before the internal combustion engine is started. The delay between powering the car on and starting the internal combustion engine is approximately seven seconds.
Brilliant to say the least. The engine is warmed up using this "hot coolant" stored in a vacuum flask (much like a thermos for heat conservation) before the engine kicks in. Virtually no start-up wear. One more reason I love my car.
