I have a friend with 03' Civic w/158K cracked exhaust manifold and recently had check engine light on for PO325 (Knock Sensor). I believe the manifold has been cracked for awhile. Can a crack in the manifold cause a knock in the engine. The quote for the repair was $1.6K for parts and labor and replacing a catalytic converter . Does that seem reasonable for the work? I figure it is, just thought I would ask. I also wondering if the crack is fixed (aka replaced manifold) will that for sure make engine knock to go away. As sure as you can be with anything. I don't believe there any other codes on car besides a (P1298 –ELD Voltage Low).
The owner of the car at the point where wondering if they shouldn't just sell the car.
Thanks,
Chris
Thanks,
Chris
