One of my Montero's "characteristics" is to hold onto gears longer when the spark plugs are worn down. Gas mileage also takes a serious hit, and power feels down. All goes right back to normal as soon as you replace the plugs. The recommended interval for spark plugs are 25,000 km (15,625 mi) with the factory NGK BP5ES copper plugs.
At my last interval in April '11, I decided to step up to NGK Iridium IX 2115 (BPR5EIX11) plugs, which have been on for the past 31,071 km (19,420 mi). This engine has a distributor setup, and I did this in hopes of running the plugs to 100,000 km (62,000 mi) so the distributor cap and rotor, plugs and wires are all replaced at the same interval, but it seems the plugs need to be replaced again.
I reckon the quality of the gas has quite a role to play, and I've already switched to Euro V, but I was wondering if anyone experienced with this engine had any recommendations on plugs.
Should I stick with iridum or step down to double platinums? If I stay with iridiums, are Denso 5305 plugs a good choice? What about Autolite XP64 or Champion 9007 plugs?
Also, one of my wires snapped off the bracket and touched the EGR tube, so I need new wires as well. I usually go OE with the cap/rotor and wires, but I'm considering going with Denso 6716204 or NGK 9545 wires this time round. Either of these a good choice? Thanks!
