Hello everyone, name's Pig and this is the first post. I have a mild modified Chevrolet SB 350. I have a more aggressive cam over stock that also has the correct valve springs for the application. It's a flat tappet cam with hydraulic lifters. I run a high volume(not pressure) oil pump. I also have timing gears(not chain) in the front.
I am almost finished with the break in of this engine. Used the Comp Cams 10W30 Break In Oil. I am a huge fan of synthetic oils as all my other vehicles have it and perform wonderfully with it.
As I was researching parts and consulting with my local speed shop I was made aware that since I am using a flat tappet cam that it would be best to use ZDDP additives every oil change(which I am not opposed to doing). However I can not find any oil lists where it tells me what synthetics are compatible with ZDDP. I know the Valvoline VR1 has it but its only 20W50 and I would like to start it in the winter when its below 20F.
So my question is what Full synthetic oils in the 10W30 or 10W40 range can be successfully mated with the ZDDP and still not destroy the lifters?
Please note: I have read that this site has a lot of Pennzoil fans. I am not a fan of this brand and had many engines overhauled cause of the use of this oil. So please no Pennzoil is great oil mantras. I know what that oil does and wish not to have my engine succomb to the same fate.
Thanks in advance to those who reply.
