Originally Posted By: Jim Allen
Used MMO for the first time a few weeks ago. Normally I'm not an "additive guy." Nothing dramatic to report.
I was given a very tired, abused and neglected Ford LGT tractor (Kohler K-Series cast iron engine) that had been sitting outside abandoned for a number of years. It was mildly stuck but came loose with just a little WD40 in the cylinder. Changed the oil did some fuel system repairs and started it up. Runs well but smokes a little and uses oil. I've ran it about three hours and the smoke had been slowing down some but I decided to see if this "legendary" snake oil might have some effect. Put it into the gas AND the oil. In the oil, I used it to thin some 15W40 Rotella to about a 30 grade (calculated based on volume and a blending chart). If the rings are "stuck" they are getting hit from both sides. So far, no changes, but it's only run an hour or so since.
Solvent based snake oils were much safer to use in the older non turbo engines. Modern turbo charged engines need modern oils with a fully functioning add pack and some of them like VW TDI's are very sensitive to the exact oil type. When you add snake oil to a good quality major brand oil, you mess up the way that oil functions and waste your money.
