1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
05/26/16 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
05/26/16 10:07 PM
Most advanced oil on the shelf?
by Jetstreamz06
05/26/16 09:41 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
22 registered (cobra7279, bbhero, chrisri, Bandito440, 3 invisible), 474 Guests and 331 Spiders online.
57996 Members
66 Forums
249469 Topics
#2835370 - 12/14/12 09:14 PM 1985 BMW 318i with M42 engine swap - oil suggest?
irish44j Offline
Loc: Burke, VA
I just swapped an M42 engine (from a later 318is) into my old 318i (used to have an M10).
Engine has been heavily refreshed but didn't rebuild, and using original pistons/valves, etc.
Mileage unknown, but compression is within factory spec.
Car is used primarily for rallycross from March to November, but also driven to events (about 70 miles highway) and driven on weekends for fun. I drive it hard. Almost always. This car isn't for leisurely cruising smile
I'm near Washington DC, but car is driven in the hot summer and cold winter here and there. Don't mind using different viscosities/oil seasonally though....
For my WRX I use Rotella T5 and/or T6 (depending on what's on sale), which I can get at wally-world of course.
Any suggestions on the best oil for the M42 in the BMW?
#2835403 - 12/14/12 10:15 PM Re: 1985 BMW 318i with M42 engine swap - oil suggest? [Re: irish44j]
Seventh Offline
Loc: NorCal
Do you have an oil pressure gauge?
I ask because I've seen a few <200k mi M42/44 engines that would get some oil light flickering action in hot weather traffic while running a 30wt oil. I've also seen them go 300k mi on a strict diet of 20w-50 conventional... but sounding like a diesel.
Considering how you drive the car, I'd be inclined to recommend just using the T6 for simplicity's sake since you're already using it. Watch consumption and pressure if you can, and do a UOA or two to see if things look ok. I can't imagine they won't.
'11 WRX E85 convert-31k-Eneos 5w40
'95 325i-commuter-176k-Caterham twist-UOA in 9k
'96 332ti-133k-DELO 5w40
'69 GTO 428ci-DELO 15w40
'58 F100 331ci-T5
#2835415 - 12/14/12 10:33 PM Re: 1985 BMW 318i with M42 engine swap - oil suggest? [Re: irish44j]
JHZR2 Offline
Loc: New Jersey
Rotella 5w40 is a great choice and Ive used it for years in my M42 in my 1991.
M1 HM 10w-40 is also a robust ACEA A3 oil that you might consider.
#2835441 - 12/14/12 11:09 PM Re: 1985 BMW 318i with M42 engine swap - oil suggest? [Re: JHZR2]
irish44j Offline
Loc: Burke, VA
Thanks. Seventh - it will have an oil pressure gauge once I'm done with this swap and actually driving the car again.
Since I don't put many miles on the car so my OCI is pretty long, sounds like T6 will be the way to go, else t5. Thanks.
#2835447 - 12/14/12 11:21 PM Re: 1985 BMW 318i with M42 engine swap - oil suggest? [Re: irish44j]
JHZR2 Offline
Loc: New Jersey
I wouldnt run T5 in it. IMO 30wt is a bit too light for the engine.
There was a time when MB for example would spec the HD or more robust version of the oils and only allow the lighter variant for really low temperatures, when the oils were low viscosity (like a 30wt).
In older manuals, 30wt is only allowable at really cold temps, in newer ones, 30wt was allowed only at really low temperatures, unless it was what is now the precusror to ACEA A3.
So if the HTHS of T5 is high enough to qualify for ACEA A3, you might consider using it... But Im not sure it would meet this.
Your selection aligns to this:
SPecial oils are in my interpretation, wider viscosity synthetics, but the basic premise of 40 or 50wt still stands.
#2835465 - 12/15/12 12:44 AM Re: 1985 BMW 318i with M42 engine swap - oil suggest? [Re: irish44j]
dparm Offline
Loc: Chicago, IL
I would run any quality 5w40 and call it a day. T6 is a good value oil, as are pretty much any of the other 5w40 HDEOs.
2011 BMW M3 sedan ZCP
#2835574 - 12/15/12 07:27 AM Re: 1985 BMW 318i with M42 engine swap - oil suggest? [Re: irish44j]
fdcg27 Offline
Loc: OH
Mine seems to do very well with Maxlife 10W-40.
Either the green or the red bottle would be appropriate.
I had a very good UOA using Maxlife Nextgen 10W-40 for 4K last summer.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#2835698 - 12/15/12 10:27 AM Re: 1985 BMW 318i with M42 engine swap - oil suggest? [Re: irish44j]
KCJeep Offline
Loc: Mahzurrah!
The Rotella 30 wts have an HTHS of 3.5, on the thick side for 30's and right at the level recommended for many German cars, but I wouldn't run a generic PCMO 30 in it the HTHS would be 3.0-3.1 for most of them.
2004 Jeep Grand 4.0 @ 132k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 57k, Ford Focus 114k, Chrysler Sebring 184k, Chrysler Concorde 115k
#2835734 - 12/15/12 11:12 AM Re: 1985 BMW 318i with M42 engine swap - oil suggest? [Re: KCJeep]
Seventh Offline
Loc: NorCal
T5 is a great oil, and I completely agree with this statement, however the oil light flickering I spoke about was on M42/44 cars running the BMW synthetic, which is also 3.5 HTHS.
He will be better informed with pressure and temp gauges, but I still wouldn't run any 30wt oil in that car during warmer months if it's getting thrashed like the he suggests. $.02
'58 F100 331ci-T5
#2835916 - 12/15/12 02:36 PM Re: 1985 BMW 318i with M42 engine swap - oil suggest? [Re: irish44j]
OVERKILL Offline
Loc: Ontario, Canada
M1 0w40 or D1 5w40 would be good choices as well here.
02 Expedition
06 Charger R/T
14 Charger SRT-8
