Free: 5 Quart jug Peak 5W-30
by Indyvwhonda
05/04/16 01:01 AM
Subaru Oil Burning Class Action
by Bandito440
05/03/16 11:43 PM
'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
05/03/16 11:06 PM
What is the purpose of a 4.4 litre oil container?
by vitez
05/03/16 10:56 PM
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
05/03/16 10:38 PM
Briggs and stratton flathead?
by pdxglocker9mm
05/03/16 10:27 PM
Charcoal
by dlundblad
05/03/16 09:43 PM
2013 Dodge Dart: replace AF on miles or time?
by vitez
05/03/16 09:20 PM
Rotella T5 10w30 or QSUD 5w30
by GumbyJarvis
05/03/16 09:04 PM
People running thru red lights. You ever follow th
by motor_oil_madman
05/03/16 08:30 PM
747-400 versus 747-8
by mjoekingz28
05/03/16 08:22 PM
14psi bypass pressure for small engines?
by motor_oil_madman
05/03/16 07:47 PM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
42 registered (asand1, BigD1, cadfaeltex, Bladecutter, bbhero, 4 invisible), 735 Guests and 301 Spiders online.
57790 Members
66 Forums
248435 Topics
Page 2 of 2 < 1 2
#2834507 - 12/14/12 07:48 AM Re: Tire noise or wheel bearings? [Re: mechtech2]
NateDN10 Offline
Loc: Rochester, NY
Originally Posted By: mechtech2
Wheel bearing make noise before they can be felt to be loose.
If yours are the simple 'bolt on a new hub' type, consider a Rambo shoot 'em all approach, and replace them both.
BTW, at 30k, what do you expect from your tires now? They are past their prime.
The all-seasons are past their prime, but the winter tires have less than 10K on them.
Upon further investigation, it does appear that these are the "bolt on a new hub" type. When I get a chance I'll try the various suggestions to try to determine whether they're bad, and then it shouldn't be too hard to replace if necessary.
2005 Chevrolet Cobalt - 95,000 mi.
2012 Mazda5 - 80,000 mi.
#2834971 - 12/14/12 03:22 PM Re: Tire noise or wheel bearings? [Re: NateDN10]
mechtech2 Offline
Loc: Chicago Area
Wheel bearings can be pretty bad without feeling looseness manually, or roughness.
It is NOT a sure test.
Only if it is REALLY bad is this helpful.
#2835545 - 12/15/12 06:08 AM Re: Tire noise or wheel bearings? [Re: NateDN10]
SteveSRT8 Offline
Loc: Sunny Florida
^^^OMG! If you can FEEL the bad bearing from the drivers seat in steering response you are likely in danger of catastrophic failure!
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2835658 - 12/15/12 09:15 AM Re: Tire noise or wheel bearings? [Re: NateDN10]
Danh Offline
Loc: Illinois
My experience is that tires can become noisy as they age even if tread wear is uniform, so I wouldn't exclude the tire possibility just yet, especially as winter tires tend to be noisier than all-seasons.
If bearings are expensive, you could try a new set of tires. Most tire manufacturers provide a 30 day "test drive". If you keep the old tires and the new ones don't solve the problem, you can return them for a full refund and put the old ones back on. Cheaper than experimenting with wheel bearings.
Edited by Danh (12/15/12 09:17 AM)
Page 2 of 2 < 1 2
