Originally Posted By: 3311
The operational viscosities, except for 1 track session, are in the 30wt range. Mid grade at that for your street use.
The same could be said for almost every car running a 20W oil...the "functional viscosity" almost never matches the weight printed on the label, particularly since most vehicles spend most of their lives warming up to operating temperature. I doubt my own car has every seen 100C oil temps in the 135K miles of its life.
Not really running a 20wt IMO. Kind of like Dr. Hass(although his oils have a higher hths as you have correctly pointed out on many occasions).
Actually, it's not like that at all... AEHaas is running a "20W oil" with high hths when measured according to the standard measurement of 150C.
Nevertheless, in both instances the operational viscosities are a bit misleading when you think of a vehicle being "tracked" with 0w20. Not casting aspersions at anyone or making an accusation that anyone was trying to be misleading, of just stating and observation.
Why not make the same observation on every other UOA? The only real difference is that in this case the owner knows the oil temperatures. The comparison to Aehaas' car is a false one, since this is a car being driven hard--the oil temps are just a function of the design, much like a lot of other cars. This isn't a supercar being driven as a grocery getter.
