So this project is finally done. Drilling out the old rear sway bar links was time consuming but generally easy. The new Quick-Struts were a direct swap except for some initial alignment issues getting the top hats through the body. Piece of cake on the fronts, not so much on the rears since they are inside the cabin. The new Beck/Arnley links look to be good quality (made in Turkey?).
Like the front, the rear now sits about 5/8" higher which is negligible and fortunately even. The new rears made more of a difference than the new fronts did, and as I suspected, was more in need of replacing. The ride seems quite a lot better with a bit of the 'new car' steering precision restored but I still wish the fronts were firmer. I'm thinking the spring rate is a tad softer than stock which I was initially concerned about, but at this point, it's done and I'm satisfied.
Now, just waiting on that $125 rebate from Monroe...
