Hi,
I just bought an '06 Jeep Wrangler Unlimited (LJ), w/the 4.0L I6 engine.
I had some 0W-30 GC lying around, so I changed the oil using it, together w/a NAPA oil filter. The Jeep's owner's manual says to use 10W-30, so should I have any problems using the 0W-30 GC in it?
For it's normal operating temperature, it's still a 30 weight. Actually, from what I've read, it's a heavy 30 weigh, being more like between a 30 and 40. So would the 0W vs. the 10W, be a problem, especially here in the northwest?
The GC also is an ACI Service SL oil, which because of it's higher Zinc content, should be better for the 4.0L engine than the newer SM or SN, which have less.
I've read that people like using M1 High Mileage, because of it's high Zinc content, so how does it compare to the GC?
Thx
Thx
