After researching online whether you should use the blue washers it comes with, or crush washers, I decided to go with the blue washers it came with. You can use either washer. You can find success stories with both types.
*Many people use both the blue washer and an additional OEM crush washer to get it to align up at 12 o'clock. I wasn't concerned about it being @ 12 o'clock as it works in any position just fine.
I'll be curious to see if it stays dry with no leaks. I don't see why it should leak at all. If it does leak, I'll switch to the crush washers, but I don't see that happening.
I followed these exact procedures:
