This is the latest UOA from our Cat Challenger MT765B with a C9 engine. Uses a Fleetguard LF9691A venturi combo oil filter. This is the second year this oil has been in service. I made mention in another post about the copper being high in this one too which seemed odd since I've done other UOAs on this one that showed very low copper. Using Service Pro 15w-40. I know it uses some oil as I added a gallon a few weeks prior to the UOA.
Hours 1548, 1868
Oil hrs 255, 575
Iron 35, 41
Alum 3, 3
Copp 1, 289
Lead 0, 1
Tin 0, 1
Sili 11, 3
Moly 25, 26
Boro 17, 10
Magn 1068, 884
Calc 1399, 1235
Bari 1, 0
Phos 1329, 1048
Zinc 1506, 1234
Fuel .6%, .5%
Soot .1%, .1%
H2O Visc 12.5, 12.5
TBN 6.12, 6.07
Oxid 12, 14
Nitr 18, 10
Even though its built for it, this tractor doesn't see a lot of hard, heavy work. Mostly pulls our corn planter in the spring since it causes low soil compaction with the tracks and then we used it to pull our grain cart in the fall when the fields were too wet for a wheeled tractor.
Hours 1548, 1868
Oil hrs 255, 575
Iron 35, 41
Alum 3, 3
Copp 1, 289
Lead 0, 1
Tin 0, 1
Sili 11, 3
Moly 25, 26
Boro 17, 10
Magn 1068, 884
Calc 1399, 1235
Bari 1, 0
Phos 1329, 1048
Zinc 1506, 1234
Fuel .6%, .5%
Soot .1%, .1%
H2O Visc 12.5, 12.5
TBN 6.12, 6.07
Oxid 12, 14
Nitr 18, 10
