Last year at the end of the snowmobile season I noticed what looked like a black oily/watery fluid coming from my right side wheel bearing.
I greased the bearing with the bearing buddy to see how much I could push out.
I managed to get some out but ran out of time figuring I would look again in the fall.
Today, after getting the trailer home, I had another look and noticed it wasn't near as bad (must have got most out in the spring?)
I planned on replacing the bearings but thought I would pump them full of grease to see what I would get and today, after doing that, I also got some lumpy/jello type lumps out of it?
I continued to pump with my new grease (Amsoil Water Resistant)until all I got was it after pushing out the old.
Just curious what this might be?
Is it signs of incompatible greases, or old grease or something else?
I bought the trailer used so I have no idea what the previous owner used but I have been using the Amsoil grease for aout 3yrs now (Just a few pumps every now and then)
The wheels turn freely and there is no play or noise anywhere while spinning the hubs.
Should I go a head and replace the bearings even they feel/sound good or do you think it is good enough that I probably pumped out all the old grease?
