Originally posted by T-Keith: It's well known that Bosch plugs have less plugs to cover more applications. That means that the heat ranges tend to be farther from Ideal. Heat ranges matter more in Forced induction and high compression engines. Perhaps their plug for the Toyota is spot on. -T Maybe some Toyota's get along ok with them. The 3.0L might be ok, but in the 3.4L used in the trucks the +4's are known for thowing codes. I've seen no evidence that anything works better than stock in those engines...
I have a good buddy that is a Master Toyota tech........he refers to Bosch plugs as 'Botched'.....says they don't do well in Toyota engines. ND or NGK is what he recommends.
