What happened to this kind of oil change?
by OneEyeJack
05/06/16 01:44 PM
OH! OH! Gas/Diesel mixup
by azjake
05/06/16 01:09 PM
VOA Pennzoil Platinum Euro 5w40 - SN
by agpatel
05/06/16 12:36 PM
VOA Liqui Moly Leichtlauf High Tech 5w40
by agpatel
05/06/16 12:30 PM
VOA Castrol Edge with Ti - 0w40 - SN - Euro Form
by agpatel
05/06/16 12:27 PM
Magnatec 5w30 - Push Mower
by SavagePatch
05/06/16 11:31 AM
RAM 1500 EcoDiesel filter
by pb379
05/06/16 09:14 AM
Motul 8100 X-Cess 5W/40 11,568Miles BMW335i
by strongmad
05/06/16 08:52 AM
Lawn Tractor Utility Upgrade
by bigdreama
05/06/16 08:50 AM
Help with iphone on the home network
by buck91
05/06/16 06:45 AM
2003 lesabre battery change back seat type
by snake123
05/06/16 05:43 AM
Penrite 0w-16
by toyota62
05/06/16 03:31 AM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
100 registered (901Memphis, 97f150, 19jacobob93, 3800Series, AEHaas, 9 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248547 Topics
#2811575 - 11/23/12 01:52 PM Isuzu NRP Diesel oil recommenation
kenpoed Offline
Loc: Pennsylvania
Stupid question, I cant seem to find any info in the owners manual whether the oil should be synthetic or conventional. All it states for the 2013 Isuzu NRP is that it should contain "CJ-4" and support "DPF"
Where can I find a site that will tell me the type of oil and filter for this truck unit? Thanks
#2811582 - 11/23/12 02:07 PM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
dparm Offline
Loc: Chicago, IL
Amsoil website should be able to help. You can pick your manufacturer and engine type to get the recommendation.
2011 BMW M3 sedan ZCP
#2811744 - 11/23/12 06:06 PM Re: Isuzu NRP Diesel oil recommenation [Re: dparm]
kenpoed Offline
Loc: Pennsylvania
I appreciate the link, unfortunately it does not give any help on the Isuzu model.
#2812204 - 11/24/12 07:04 AM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
m37charlie Offline
Loc: Alaska
Virtually any heavy duty diesel oil sold in auto parts stores, Walmarts, etc will have an API rating in the back or front label of the container, which these days will be "CJ4", at least in the US. This by definition "supports DPF".
You don't need expensive Amsoil products for this engine especially if you plan to follow the mfgs recommendation on oil changes. Save the $$ and perhaps use synthetic for the differential.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#2812615 - 11/24/12 03:11 PM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
The book does not even mention a viscosity? That's lousy support. I can ask Amsoil if you like.
Just as a point of reference the Amsoil OE Diesel line is about $5/qt.
#3320730 - 03/23/14 10:30 AM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
Red91 Offline
Loc: Alabama, United States
I believe any 15W-40 or 10W-30 HDEO will work. The newest spec is DPF safe.
'15 Chevy Cruze LS
1.8 4 Cyl, 6 Speed Auto
QSUD 5/30, STP XL Filter
'92 Buick Roadmaster Wagon
5.7 V8, Auto
QS 20/50, LMMoS2, Napa Gold Filter
#3320857 - 03/23/14 01:15 PM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
simplistic Offline
Loc: Tennessee
I have owned 3 of these npr with diesel engines. Any of the 3 big players (rotella, delo, and delvac) will b fine. I ran which ever one was cheaper.
As far as viscoity it the manuel don't show it (though its n there some where) look on the driver's sun viser. It's on the back side and it shows anything from 5w30 to 40wt and the temps that each is acceptiable. though 15w40 has almost as big of temp alowence as 10w30. You can run either with out problem.
These engines are basiclly 1/2 of a durmax engine. I ran mine hard and only did routine mantiance nothing more.
03ccsb,2500hd 200k+ Durmax/Allison,PURE POWER FILTERS,Bilstin Shocks,Aux Springs,Swiss Cheese Air box Fram Tough Guard,BF Goodwrench K/O
#3475741 - 09/06/14 01:35 PM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
I try to stay away from the synthetic with those trucks, because of the signature oil leak that develops at the back of the cylinder heads of pretty much all of them. The synthetic just makes it worse.
Rotella T5 10/30 or the NAPA Heavy Duty "Premium" 15/40 is what I've always used, and the trucks I service are at or above 250k miles. The engines themselves are solid. The EGR valves are another story. laugh
2007 Lincoln Navigator M1 0w-40/FU
1968 Charger R/T / Supercharged 440 VR1/DBL7349
2007 Ram 3500 4x4 / Cummins 6.7 /DBL7349
2015 Porsche 911 C4S PDK
