This is my 2001 Ranger with 77,000 miles on it running a fresh batch of Redline 5w20. So I installed a mechanical oil pressure gauge tonight. Hot readings are great:
Idle: 20 psi
2000 rpm: nearly 40 psi (spec is 29-39 at this speed)
keeps going up to about 85 psi somewhere upwards of 4000 rpm.
Could not get it to 90 psi even with 5500 rpm runs.
Quite a range! Really would have thought that the bypass should open lower than 85.
Idle: 20 psi
