Originally Posted By: ltslimjim
Originally Posted By: The Critic
Originally Posted By: Cooper
I am getting ready to do the brakes on my Nissan Altima. What is the best DOT 3,4 brake fluid available. I have used Valvoline stuff before, and it makes the brakes feel a little mushy. What are some opinions?
One of my buddies uses Valvoline DOT3/4 fluid at his shop (white bottle) exclusively. I've always felt that the brake pedals on his customers' cars felt a bit soft after a flush with a pressure bleeder, but he insists that the feel was normal for the make/model. This isn't the first post that I've read about Valvoline DOT3/4 causing a softer pedal. Very odd.
Strange coincidence, my pedal is soft right now.
Today, I did a brake flush flush on my mother's DD, which is a 2010 Altima V6 with 17k.
I used the white-bottle Valvoline DOT 3/4, two quarts of it, with my Motive Pressure Bleeder at 20-22 psi. Pedal is indeed firmer and the mushiness that had recently developed is now completely gone.
So, if you are getting a soft pedal after the flush, then there was a problem with the procedure.
