I just ordered 6 Autolite Iridium (XP104) spark plugs for the grand sum of $14 after rebate.
I thought that for that cost, I may as well put them on my almost 9 year old / 70k Taurus sooner rather than later and enjoy the improvement.
I've never done spark plugs before and need tools. The instructions for my vehicle are here:
http://www.taurusclub.com/wiki/index.php?title=Changing_the_Spark_Plugs_on_the_Duratec
The backs are known to be tricky. So it is recommended to have some various bits and pieces as follows
A spark plug socket, 8 inch extension and ratchet will reach the two plugs closest to the passenger's side of the car.
In order to reach the plug closest to the driver's side of the car you will need the socket, ratchet, 2 four inch extensions and a Universal joint to go between the extensions. There is an obstruction in line with where you want to be so you need the U joint.
Where and what brand is my best option for these tools?
Is there anything else you recommend for someone doing this for their first time?
