A guy on a Subaru forum cut open a factory map in-on filter and showed it had an entirely different design than aftermarket oil filters which claim they are suitable for Subaru trans, eg Wix 51356. However, oil filters have a by-pass valve whereas the factory Subaru filter has a perforated plate/screen instead of a by-pass valve so you always have a flow of ATF to the cooler even if the pleated media is clogged.
My friend had her 2007 Outback serviced recently and they made two mistakes. First they flushed with 10 qts of Dexron before adding 6 qts of Subaru ATF. That means her trans now has 40% Dexron which Subaru says can be used only temporarily.
The other mistake was they removed the factory external filter and replaced it with a Carquest 85356 oil filter.
I know we need to get the Dexron out of there, but should we also replace the filter? Thanks.
