Had this problem with our 04 Escape for a while now (2 years 10+k) and I think it's finally getting worse. At idle in either park or neutral has a looping idle, never happens above idle. Will vary from normal idle up to 1k maybe more. Has a distinct popping noise coming from the intake. No codes right now. Did have one (can't remember the code) that dealt with the EVAP system detecting to much air flow. I put some MMO on the gas cap seal and it's been off for about a month.
Sparks plugs have around 40k, all filters are new. I'd pay for a code right now! On a recent trip averaged 23.5 and seems to run fine otherwise with plenty of power. The power steering did have a leak but that's been fixed. Some have pointed towards the MAF, IAC or few other sensors. All sensors are factory. I did replace all the vacuum lines under the hood. Any ideas?
