1999 Harley Davidson 1450cc Twin Cam 88. 37,817 miles on unit. 2628 miles on oil. Mobil 1 15W-50 Extended Performance. In use about one year. No make-up oil. Fairly well always brought up to operating temps when ridden. Mostly ridden two-up and often very hard, but not as much this OCI as with others. Wix paper oil filter. Screaming Eagle (K&N) air filter. Sample taken 4-24-06. Analysis by Blackstone 5-1-06.
good! No problems found here.
My comments: Since this is still (barely) a 50 weight at temp and TBN remains good I think I’ll top it off and leave it in for another year.
Blackstone comments: Fuel contamination dropped from 1.8% last time to less than half a percent this time, which is a nice improvement. We don't think your Harley has any sort of fuel system problem. Wear still looks great and all metals improved on this shorter oil change. The universal averages column shows typical wear from this type of engine after 3600 miles on the oil. We don't think you'd have any problems if you added 2000-3000 miles to this fill for the next sample. The TBN read 8.6, still lots of active additive left. Lookingcode:
This Univ
Report Avg
ALUMINIUM 4 5
CHROMIUM 0 0
IRON 15 15
COPPER 13 20
LEAD 3 2
TIN 1 1
MOLYBDENUM 73 26
NICKEL 0 0
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2
BORON 203
SILICON 9
SODIUM 5
CALCIUM 2794
MAGNESIUM 60
PHOSPHORUS 1070
ZINC 1324
BARIUM 0
SUS @ 210*F 83.3 (16.48 cSt @ 100*C if my calculations are correct)
Flash 385*F (flagged – should be >390*F)
Fuel
Antifreeze NA
Water 0.00
Insolubles 0.1
