Having bought a '12 Accord 4cyl, I'll need to select a 0W-20.
Out of these oils, from what I've read here, TGMO seems like the best choice.
It really goes against my past practice to leave the FF in a new engine beyond 1K, but Honda is very specific in stating that it should be left in for the entire MM interval.
Honda started using a special breakin oil in 1996, though, and I can tell you that I drained the FF of the '99 at 1K and then put it on an M1 5W-30 diet for a number of OCIs, with no ill effects 160K later.
I'm thinking that the FF should probably come out at around 30% MM, and I'm thinking that I'll then do a couple of similar runs using near FAR PP and QSUD, and will then settle on an oil to use long-term.
I don't think there's any point in a UOA before 20K and a FF UOA would only be good for frightening small children.
What would all of you think about using TGMO?
Also, while I know that the subject has been beaten to death, how long have other K24 owners run the FF oil?
