dnewton3
Staff member
I love it! Big runs on nothing but a "normal" filter. Yes- Baldwins are good filters; if you have plenty of them, use them!
What I did this year with my Dmax is sample via my Fumoto, and send it in. Report came back fine; so I didn't OCI. I can easily go another year, given my operating pattern. I'll UOA again next fall, and make another determination. That is the beauty of the Fumoto valve; you can sample, get the info, and only then do you need to decide on any action required! Fumoto's not only make oil changes easy, they make oil sampling super easy!
I run my samples "live" (engine fully warmed up, engine running with truck in park, clean the valve, and pull the sample into the bottle while it idles. That is a true representation of the oil in its natural running state).
I would suggest considering this:
- At the next OCI, reset your OLM.
- Use the OLM to indiate when to take a sample; build some history. Each time the OLM indicates a change take another sample and gage the predicted lifecycle to see how much life is left in the lube; you'll be suprised how effective that can be
- Also use the OLM to FCI (filter change interval); it's an easy way to keep both in sync between the UOA and FCI patterns! Each FCI offers a bit of "top off" to replace the volume.
You follow that program, and you might just get to 50k miles!
